Because my machines old and not in production anymore i would like to try and get another coil to fit my machine,ive just fixed my 8.5 widescan but would like a larger coil like a DD OR sef coil,i see that they are making sef for 10khz and 12khz for tesoros,ive kept a four pin connector that came off a spare coil that came with the machine,and ive worked out the wiring for a four pin tesoro coil but it didnt perform aswell as my widescan,even though my coil is a four pin it has five wires inside cable but the tesoro only had four,i had a coil from this machine checked for the MH values and they are RED,BLACK+BARE WIRE -5.6MH AND WHITE,GREEN/5.4MH CAN YOU TELL WHAT KHZ MACHINE RUNS AT FROM THESE VALUES,AND CAN ANY ONE SUGGEST A GOOD COIL THAT MIGHT DO THE JOB
I have MH values for my coil please help!
What is the make and model of your machine?Originally posted by dejavuband View PostBecause my machines old and not in production anymore i would like to try and get another coil to fit my machine,ive just fixed my 8.5 widescan but would like a larger coil like a DD OR sef coil,i see that they are making sef for 10khz and 12khz for tesoros,ive kept a four pin connector that came off a spare coil that came with the machine,and ive worked out the wiring for a four pin tesoro coil but it didnt perform aswell as my widescan,even though my coil is a four pin it has five wires inside cable but the tesoro only had four,i had a coil from this machine checked for the MH values and they are RED,BLACK+BARE WIRE -5.6MH AND WHITE,GREEN/5.4MH CAN YOU TELL WHAT KHZ MACHINE RUNS AT FROM THESE VALUES,AND CAN ANY ONE SUGGEST A GOOD COIL THAT MIGHT DO THE JOB
