I used Qiaozhi's coil calculator V.2 to calculate the coil for a surf pi that I try to build using the info of the forum and the board that silverdog supply.
Coil diameter 210mm,wire diameter 0.48mm 16 turns the calculator give's me 0.379mh.
its all good to now.
I made the coil 16 turns, tie and cut the wire, and then measure it with my new LCR meter,and here is my problem.
the meter reads 0.171mh.
am i missing something, is the coil calculator wrong , or I got a dad LCR meter?
i would like to know what do you think.??
Nickel_n
Nickel_n
