Hi Tec,
You are right. I was using 1oz copper for my pcb, so the higher resistance. Pancake or spiral wound coils are the least efficient. Better to have square or round profile , so that all the inductors can interact.
If I were spending the money. I would do a 4 layer with 6 or 7 turns per layer. Don't worry to much about the resistance, some of Eric Fosters best beach detectors had series resistance of 3 ohms plus he would add a 27 to 39 ohm fixed resistor between the mosfet and coil. This acted as a current limit and also sped up the recovery for early sampling.
What did that proto coil cost, if you don't mind saying?
