I have a Tesoro Tiger Shark and recently picked up a clean sweep coil which is compatible with it. The problem that I ran into is that Tesoro does not make the adapter cable to attach the clean sweep to the detector any longer. They stopped because it was not waterproof. I mailed them and asked if they can send me the pin pattern for the cable and they won't provide that so that I can make my own adapter.
Does anyone out there have a cable that they can throw a continuity tester on to send me the wiring information. Pins are numbered on both ends. I just need to know if they go from 1 to 1, 2 to 2, etc. since the pin patterns are different.
Otherwise, can someone tell me if it would hurt the machine if I tested all of the possible combinations until I figured out the correct configuration?
Thank you,
John
Thank you,
John
