Sorry for this posting but i think there are many people out there which will be the victim of murphys law.
The last times i made coils on my easy coil winder like many other here in froum with wood plate and these good wooden sticks. Winded by my own hands turn by turn.
Now i had the idea to make a simplier coil winder, it contains ball bearings, metal screws instead of the good wood sticks and a calculator which is modified to a counter with reed switch- nice thing i thought i was so proud of it.
But when i did my tesoro coils last weekend i had a bad awakening- i measured the coil inductance so that i had exactly the coil specs that were right. But i measure when coil were placed in my nice machine- with all these metal components - i couldnt imagine that these parts will influence my testing result.
I take the coil off glued it and taped it and test it again
the inductance driftet to a lower result - this cant be i thought. After tighten the coil on my machine the windings had the exact specs and the only thing what can happen when i taped it that it rises a little little bit.
But now after drinking my friday evening beer after a hard working week it came to my mind - sh*t metal trash- i run into my lab
and tested my coil on the winder and off coil winder- that is it.
So keep in mind - DONT measure your coil inductance with any metal parts nearby. You CANT get the right result.
Tomorrow i will change all metall screws with nylon bolts for first.
So good night.
the inductance driftet to a lower result - this cant be i thought. After tighten the coil on my machine the windings had the exact specs and the only thing what can happen when i taped it that it rises a little little bit.But now after drinking my friday evening beer after a hard working week it came to my mind - sh*t metal trash- i run into my lab
and tested my coil on the winder and off coil winder- that is it.So keep in mind - DONT measure your coil inductance with any metal parts nearby. You CANT get the right result.
So good night.
