big coils
  • big coils
    im working on a big coil for looking for meteorites. it osc is 125k . checking (air test) i notice a frequency change at about 5ft with a plate. now the loop is about 4 1/2 feet across. im going to make a second osc at 125khz and combine the to freqencies. anyone got any suggestions for improving it. i here the higher frequencies get better penetration into the ground. true/false?
    Take a look at the metal detector projects section on this site. There's one with a frequency multiplying mixer, I think it's the ETI561 project. That might give you some ideas, as might some of the other BFO projects.
      i have gotten the second ocs to 123k the first one with the big loop is running at 128k. i am wondering if i took the difference of the to(5k) squared it off and used a pic chip to measure the pulse width , would it be sensative enough?
        Don't let me stop you putting a micro in it, could be fun. But you will find your ear is just as capable. Set the difference freq to 200Hz, and you will find a frequency change to 220Hz is audible.
          i moved a small plate towards small coil and it drove the freq up to 132k . i will place the small coil in a box in such a way to enable the frequency adjustment by adjusting the plate distance from the coil.
            What you are describing is a BFO design. Besides being relatively less sensitive, BFO's also have a stronger response to minerals, making them less stable. Most meteorite detectors use PI designs.
              so does higher frequencies get better pentration? this is my first attempt at making a metal detector. basically its two ocs tuned to the same frequency.
                Generally the opposite... lower f's go deeper.
