I didn't get the stock 18" DD coil with my GP Extreme so I'm interested in making an 18" coil but not sure what to try first. I'd like your suggestions. I see guys using litz wire, wire from USB cables, varnish-coated bare copper, coax center conductor spiral...
DD vs Mono?
I likely will be searching Arizona soils which typically are high iron oxide accompanied by hot rocks and 50 cal. bullet casings...
What confuses me is that with all the talk about interwinding capacitance and teflon vs air vs kynar vs whatever, stranded wire vs solid, there are several guys that use solid varnish-coated copper and do ok...
I will have to depend on a Hays housing - so mono/dd/oval?
Barry
DD vs Mono?
Barry
1) MOSFET COSS, (2) Coax wire type and length, (3) coil winding technique, (4) coil wire type, (5) coil wire size, (6) Wire insulation thickness, (7) wire insulation Dielectric Constant, (
Shielding material, (9) coil to shield spacer. Higher value damping resistors result in steeper TX turn off curves that can be damped earlier to allow a little less delay, thus being more sensitive to a little smaller target.
