surf pi coil question
  • surf pi coil question
    Advice needed on the number of turns needed
    coil dia id 20cm 8" od 22cm 81/2" former 10mm wide former machined from thick walled plastic water pipe.
    How many turns, can i use 7/0.2 hook up wire have several reels or do i need thicker wire & less resistance
    can i use a single cable from board make coil and return to board, section above coil inside heatshrink cable.
    would it be best to add a shield if so does it make a difference if it's connected to start or finish of coil.
    no time to experiment my grandson's are waiting to find treasure lol. thanks
    You certainly can use 7/0.2 wire, whether it allows the delay to be set low enough to detect gold would need to be tested
    I would guess at this late hour you would need around 24 turns ?
    Some members have used a coil without shielding, I guess it depends on your hunting ground
    If you decide to shield don't forget to leave a small gap, connect the shield to the pcb gnd
      I did 18 turns of 0.3mm enamelled ~ handspan diameter.
      No shield - works ok - not fantastic.
      Depth comparable with my IGSL efforts. About 5 - 6"
      Hoping idx I ordered with 27 DD will get to 8" on mid size coin lying flat..
      S
        Everything worked out grandsons were delighted PI will keep them digging lol
