Compadre coil
  • Compadre coil
    hello, is it possible that a compadre coil,
    works with a TGSL?
    works with a TGSL?
    If it is has a 5-pin connector, then most likely the answer is "yes".
    But if it has a 4-pin connector, then "no", as it has the wrong inductance values for the TGSL.
      yes this is a 5-pin connector.
      Now I need an adapter, because I use another connector, Tereso probably used an exotic connector system, at least for germany standard,
      thanks for the information
        hello herpes
        look for example
        Cool circuits, tips, techniques, PCB methods, test equipment, etc.
        last posting
        maybe you need something like this (but in 5 pin version)
