G'day all,
I've noticed in nearly all circuits the ubiquitous 1N4148 and 1N400x diodes, especially as clamping or voltage-doubling diodes.
What you may not realise is that the "super fast" version of the 1N400x family, the UF400x (and specifically,the UF4007) has a reverse recovery time that's over 30 times faster - just 75nS (typical), compared with a "perfect storm" best possible case of 2uS for the older diode types! Amazing, isn't it?
I've been using UF4007s in everything I design for most of the last 10 years, except of course where specific parameters demand a different diode type!
It might be interesting to hear if anyone tries this replacement in your front ends and voltage multipliers, and what sort of results you get. I'm particularly interested to hear if they make a difference to the front ends of the various detector designs. It would be most edifying...
The 1N4148 diodes can also be replaced, in most cases, by the UF4007. The only places I've experienced problems with this type of replacement has been in exceptionally low-current, HF applications, where it appears the UFs don't get enough current to turn fully on, and generate quite a bit of noise. But it's worth trying.
For those of us with "golden ears", any decent audio amps you might have that use the 1N400x series in linear power supplies, might benefit from replacing the 1Ns with UFs. Because the reverse recovery current flows for a much shorter period, some high-frequency distortion may be eliminated in some designs. It's just a tip, and again, if anyone can be bothered, it would be interesting to hear from you if you notice anything at all. (Please note, if you use oxygen-free copper cables, you won't be able to hear any difference, so it's not worth the hassle of replacing the diodes!
). But for anyone with normal amps, it could be fun to try!
I hope this information is helpful in some small way. Please let everyone know if you find it helps.
The oldies are the goodies, right?
Cheers,
PtB
). But for anyone with normal amps, it could be fun to try!I hope this information is helpful in some small way. Please let everyone know if you find it helps.
Cheers,
PtB
