My recently acquired c.scope 1220B came with 2 x 9v batteries attached to the two clips in the battery compartment, I knew these wouldn't last long so went to Maplin to grab 2 x 6 AA battery holders
What's my charging options here, I don't have enough chargers to charge all 12 AA's at once so will either charge them as 2 x 9v blocks (wouldn't have a clue on what charger to use or how long to charge) or charge both blocks via the dc charging socket on the 1220B itself.
I'm guessing the charging socket would be the best option but what voltage is needed, is it 9v or 18v, does the metal detector have an Inbuilt charger circuit ?
I have a bench supply that will output 0-30v at 0 - 5amp, I'm hoping I can use that as the dc charging source.
cheers
cheers
