Need help deciding on the correct buzzer for my pinpointer kit.
  • Need help deciding on the correct buzzer for my pinpointer kit.
    Hi
    I have a Velleman Metal Detector kit K7102 and the Manual recommends an optional buzzer SV4/12-S. Looking at my Velleman catalog, this buzzer has the following Specifications. Operating Voltage 8-16VDC, Rated Voltage 12VDC, Current consumption 15mA, OSC frequency 3.2 kHz, Sound level 85dB. This kit operates on a 9 DCV battery.
    I bought an electrical outlet box and cover plate as an enclosure for this kit and plan to attach a pvc tube to the side of the box to make a pinpointer for my metal detecting hobby. Of course this will entail installing the ferrite core and copper windings near the front end of the tube.
    I went to several Velleman distributors, but they didn't list the buzzer recommended. So decided to go back to the Radio Shack store in my Village where I bought the kit K7102, to see if they carried a substitute buzzer and they sold me the following: Radio Shack Buzzer #273-0074, with the following specs. on the bag. PC-Board, 12VDC Piezo, Mini-Buzzer, 3.0-16VDC, 4.1kHz, 7mA max. at 12VDC, 70dB min. at 30cm/12VDC, 4100 plus or minus 500Hz.
    Now that I'm ready to proceed with building this kit I'm having some misgivings about the buzzer I bought and have the following questions.
    Will this Radio Shack buzzer work and will the lower power battery reduce the sound level of the buzzer ?
    BTW, what does 30 cm mean ?
    Thanks for answers to my questions and please add any other comments you care to offer.
    ToddB66
    You shouldn't have any problem.
    70dB measured at 30 centimeters/roughly 1 foot. About as loud as most people have the volume turned up on their radio.
    I find 85dB borderline loud. But I have bad hearing.
    eric
      The 85dB is pretty meaningless without an associated distance... 85db@1cm is a lot weaker than 85dB@30cm. I personally find 4kHz a bit high, but it should work just fine.
        Overtheedge and Carl-NC,
        Thanks for your help!
        ToddB66
