Battery choose
  • Battery choose
    Hi all gurus
    I buy some AA Battery Rechargeable but dont work well and today when i chek them they are destroyed(can not store voltage)
    I need to your idea for buy good battery?if I buy a battery 12V ,4.5Ah (or 3Ah) and use the board that Regulation voltage for all detector(This circuit can adjustment up and down and give 2.5A.h) ,is my idea well?
    I wait to your help
    thanks and cheers
    if every one have this circuit put it here for all
    It is possible that this type of battery is excessive - maybe a little heavy.
    Sure it will power your units. I use either Lithium Iron or Lithium polymer.
    S
      thanks
      but i think Seald lead acid is good for all detector but little heave
      i buy 12volt 4.5Ah good or 12v 3Ah.
      Lithium Iron or Lithium polymer are too much expensive!!!
        Yes Mohandes Seal lead acid are the best for pulse detector ... good, practical, easy to charge, easy to find (computer break).... , but they are heavy and they charge very well , almost they are good for 3-4 years , for me it is the good choice , i have use many type of batteries and the better is the lead acid , in my pulse detector i use 12V 7amps battery heavy but my pulses are OK all the time.... 10 hours a day!!!
        But DO NOT FORGET to instal a fuse in the line +
          Hi. Sorry, I am not guru. I think, the lead acid batteries is easy choice for PI.
Name:	Accu power.jpg
            Ok thanks Aleximex , I sure about that
            [QUOTE=rael;175635]Hi. Sorry, I am not guru. I think, the lead acid batteries is easy choice for PI.
            HI my friend I am not guru too
            thanks all.
              hi all
              now i find it,but just should put battery instead bridghe diods,is it possible?can ENDURE to 5A, and it is good for this.
