Hey there,
I'm currently working on a development board for digital signal processing and I stumbled upon a (maybe trivial) problem.
My goal is to use an external USB sound card for signal in and output for a metal detector. What I'm designing basically is an interface board that plugs between the USB sound card and the metal detector's coil - nothing new.
However, when I had a closer look on the output of the sound card I found out that the audio jack's sleeve is a virtual ground potential at ~1.67V (half the supply voltage) so the output signal swings from 0V to 3.3V, centered at 1.67V.
I took the sound card apart and figured out that the output is DC coupled (no capacitor).
The problem I now face is that I don't know how to create a common ground between my amplifier PCB and the sound card - what shall I do with the jack's sleeve which is at 1.65V?
I've attached a very simple schematic of the sound card and the datasheet of the sound card's chipset.
