PI: Effects of pulse shape and transmit time.
  • Tinkerer
    Thanks, but there's now another problem.
    It cannot find the "Cree_Z-FET_Models_Rev0p3.lib".
    Here is the file.
  • Qiaozhi
    The attached symbol:CMF20120
  • Qiaozhi
    Tinkerer: Have you taken into account both the parasitic capacitance and resistance of the coil? I believe green had left them out.
    The LTSPICE inductor model allows these values to be passed as parameters. On the left of Green's schematic he shows these hidden values.
    You can actually make these values visible by using <CTRL> with the right-hand mouse button to bring up a different dialog box. Then double-click in the right-hand column (under V) to change the visibility.
  • Teleno
  • Tinkerer
  • Tinkerer
    The CMF20120 symbol is missing.
    This symbol and spice model can be downloaded from the manufacturer. I will look for it and post it.
  • Tinkerer
    While we have the sim at hand, we could look at the target response.
    We see the TX eddy currents in the targets, to the time of TX switch Off and then the new eddy currents generated by the switch OFF di/dt.
    v(n011) is the coil voltage decay
    I(L2), ..L3, L4, L5, L6 are the responses of targets with TC's of 5us, 10us, 100us, 500us
    We see how the short TC target eddy currents raise to a certain level during TX, but then start decaying again.
    The long TC eddy currents keep increasing right to the time of switch OFF, because their TC is longer that the TX time.
    We see that the switch Off must first destroy the negative eddy currents from the TX before it can build the positive eddy currents from the switch OFF.
    Now, just one more hint:
    When we use an IB coil, we can sample the TX eddy currents just before the TX switch OFF, invert the result and add it to the sample after switch OFF, obtaining an enhanced peak target response.
    Of course, if we really want some more target information, there are many many more ways to extract this information from these target response curves.
  • Qiaozhi
    The LTSpice file
    Could not upload it with CHROME, fut with FIREFOX it works
  • Tinkerer
    The LTSpice file
  • Tinkerer
    After modifying Green's SPICE circuit to make the damping resistor sink a constant current during the discharge period, I found something interesting. Although the current through the damping resistor can be kept more or less constant, the coil current is not constant. It does however decay with a linear slope, as long as you remove the series diode. With the diode in circuit, the coil current is highly nonlinear. As Teleno also observed, there is a tendency for instability at the end of the decay curve.
    Personally I'm still not convinced of the merits of this approach. As far as I can see, when you hurry along the coil current decay, you effectively remove energy from the system that could otherwise be used to kick the target. Even though it's possible to sample earlier, the same result could have been achieved by simply putting less energy into the coil in the first place. IMHO it looks like the originator of this concept is under the delusion that the coil charging period is responsible for "charging" the target, which is (as we know) is a fallacy.
    This sim is done with Zener diodes. Avalanche diodes like BYV27-200 should be better.
    The damping is faster and with a bit of twiddling locks perfect in the sim. Probably also works with real components. However, the target stimulation is indeed reduced.
  • Qiaozhi
    I'm currently simulating CC with models of actual components and there seems to be no benefit. As the current in the coil approaches zero, instability occurs (non-linearity of the current sink components) which causes underdamping and oscillations all over the signal. The optimal bias of the current sink is very critical (4 digits accuracy). Too much trouble for no benefits.
    I'm dissapointed because moodz hyped so much and I was expecting to build a more sensitive PI out of it. It won't happen.
    Will keep you posted on this with schematics, simulation code and signals.
  • Chet
    Teleno, thank you for your effort, the bottom/end of the decay is the critical area of concern. I still look forward to seeing your schematics and signals.
  • Teleno
    I don't know the benefits of using CC decay over critical damping.
  • Chet
    I think the main benefit of a constant current (CC) delay is the sharp linear drop of all energy into the target area with hopefully no energy left to cause oscillations. This will allow the op amp to recover from saturation sooner allowing detection of low conductive (short time constant) targets before the target eddy currents expire. I agree that it is not an easy task to get a CC circuit to work, this will take some research and experimenting. Thank you for answering my questions.
  • green
    Green great work as usual. Your chart indicates a very improved fall time (less than 0.33us). If this can be achieved in real circuity it will allow for a very short delay time for detecting gold nuggets. Do you think the simulation is accurate in simulating added capacitance and loading from the added circuity? Is L2 a single turn with a ratio to L1 of approximately 1 to 30 turns? I am not versed in Spice, what does the Pulse and .tran codes translate to in values? It would be nice to get a circuit like this breadboarded and measured with an oscilloscope.
    First I would kike to thank Qiaozhi for the replies. I know a lot of this has been discussed before. One thing I didn't think about, the current at turnoff is 1 amp and has to drop to the 600 ma in a short time. Change in current. I'm just trying to learn, sometimes I'm slow. I saw constant current and thought no target stimulation. The CC circuit I added to spice doesn't take the coil volts to zero. I thought it would be close enough to see if it effected the target signal. There is less signal with the CC decay with spice , but then I'm not sure the spice simulation is correct. I don't know much about spice, I just make the L2/R1 equal the target time constant I want. Looking at the decay signal across R1 makes sense to me. I have looked at target signal during coil on time with a DD coil. The scope signal is different than the spice signal. It's easy to make the coil decay signal look good with 400 volts full scale. Getting it right at 5 mv and less is a lot harder. I don't know how to make a CC circuit that would work with a real PI circuit. It looks like it would be a lot harder than adding a damping resistor. I don't know the benefits of using CC decay over critical damping. The pulse code controls V1 and turns the fet on for 50 usec and then off. The .tran takes 150 usec of data starting at time zero.
