I have been working on the Hammerhead PI, but I am not using the provided PCB. I have been designing and building each section on a separate PCB (I use KiCad) so that I can fully understand how each section works. Also it lets me re-use sections in later designs. Eventually I will combine all the sections back into one PCB.
Unfortunately I am not very good at making PCBs. Printing and etching is never a problem, but I can never seem to keep the top and bottom layers perfectly lined up.
Today I did a double sided PCB for the oscillator but realized I could not easily solder it because the holes are not thru plated, and the top and bottom layer are slightly off again. I can't solder a chip socket on the top side of the PCB : (
Maybe I will just send the gerbers out to a PCB shop instead!
What method are you using for prototyping circuits?
thanks
The silk screen on this one is not good!
thanks
