Diptrace software
  • Diptrace software
    Hi
    Take a look to diptrace software. It´s is really a very nice tool to make schematics and pcb´s
    DipTrace prodides the following features:
    Easy to learn user interface
    To design a schematic, simply select and place components onto your document and connect them together using the wire and bus tools. Multisheet design is supported. Then select the menu option 'Convert to PCB' to convert the schematic to PCB. Layout can be updated from Schematic in a few clicks at anytime. When you create or edit design objects they are highlighted to improve your work. Step-by-step tutorial available from web-site guides you through the design process and allows to get started with ease.
    Smart placement and auto-placement features
    After converting Schematic to PCB layout, place board outline and arrange components. Then use "placement by list" for chips/connectors and auto-placement for other components to get acceptable result in a few minutes and start routing.
    Easy to use manual and powerful automatic routing
    DipTrace PCB software includes an advanced automatic router that is able to route single-layer and multi-layer boards. It is available with a 'rip-up and retry' algorithm. Autorouter achieves high completion rates by going back and re-routing nets to make space for connections that could not be routed on a previous pass. Intelligent manual routing tools allow you to create and edit traces by 90, 45 degree or without any limitations. Through, blind or buried vias can be used in automatic and manual routing. Unlimited board size is supported.
    Shape-based copper pour
    Powerful copper pour system can help to reduce your manufacturing costs by minimizing the amount of etching solution required. To use it, all you have to do is insert a copper area on your board in the PCB Layout program and any pad or trace inside the selected area will be automatically surrounded with a gap of the desired size. Using copper pour you can also create planes and connect them to pads and vias (different thermal types are supported).
    Advanced Verification Features
    Schematic and PCB design modules have number of verification features that help control project accuracy on different design stages: The ERC function shows possible errors in Schematic pin connections using defined rules and allows you to correct errors step-by-step. DRC function checks the clearance between design objects, minimum size of traces, and drills. Errors are displayed graphically and you can fix them step-by-step and rerun the DRC in one click after any corrections. Net Connectivity Check verifies if all nets of PCB are electrically connected. This feature uses traces, copper pour filled area and shapes to control connectivity, then reports broken and merged nets with area details. Comparing to Schematic allows you to check if routed PCB is identical with Schematic.
    Spice Support
    Using DipTrace Schematic or Component Editor specify spice settings or attach models to the components. Then export .cir net-list of your Schematic to LT Spice or another simulation software to verify how it works.
    Import/Export Features
    Package modules allow you to exchange schematics, layouts and libraries with other EDA and CAD packages. DipTrace Schematic Capture and PCB Layout also support Accel, Allegro, Mentor, PADS, P-CAD, Protel and Tango netlist formats.
    Manufacturing output formats
    DipTrace provides support for a number of different manufacturing output formats. Using this PCB software you can produce N/C Drill files for numerically controlled (N.C.) drilling machines and RS-274X Gerber files for sending to board manufacturers. Vectorizing function allows to export true-type fonts and raster images. Also DipTrace supports DXF output.
    Producing PCBs using milling method
    DipTrace allows you to export edge polylines to DXF. The DXF files can be converted to G-code with Ace Converter (it's free). Before edge exporting the DRC function of pcb layout program checks the design and shows possible problems if exist.
    Standard component libraries
    DipTrace package includes component and pattern libraries which contain 50.000+ components from different manufacturers.
    Creation of your own libraries
    Component and Pattern Editors allow to design your own symbols and patterns. To create complete components simply connect them together using Component Editor.
    ... and much more!
    that's not all
    I tried the demo and went through the tutorial. That went well. There is no real manual, just the tutorial and the support forum. I then started a product in it. I quickly reached the pin limit so I bought the 1000 pin version. I discovered lots of quirks and bugs. As I started to get close to the 1000 pin limit, I gave up on it. Diptrace left a bad taste for me. Lot's of people complain about the autorouter on the support forum.
      Yeah and wait till your halfway thru your job making a pcb and you decide to move a component and then "all" the tracks on the other side of the board turn to ****,it did it in 1.3 and still does it in 1.5.......BLAHH.
      Zed
        Diptrace user
        Hi,to all members on forum.I am new to forum and would like to add that I am Dip trace user. I tried a few packages and dip trace caught my attention.It is relatively easy to learn compared with others.It has all facilities needed for hobbyist.A challenge to sprint users I have not seen one layout with reference designators or values.I would recommend dip trace.300 pin freeware and upon request from dip trace support 500pins free.I hope to post volksturmSSopt1 sometime.Don,t knock it till you try it.best regards MAURICE.
          who knocked it without trying it?
          Everyone who commented on it said they tried it. I bought the 1000 pin version a couple years ago. It sucked and I dumped it. Maybe it's better now but they've already lost me.
          Boattow
            DIPTRACE PROBLEMS
            Dear boattow,I am honestly sorry you had a bad experience using diptrace.I have used ver2.07 and now on ver2.1. I have no problems using it although it took me a while to learn how to use it properly it is still probably easier than most.I have made quite a few boards with it using toner transfer method.The only problem in this is you have to be careful in selecting the right image to print,in diptrace print the image with out mirroring and when you iron on,you will get correct image.best regards MAURICE.
              hi,
              what type of this film capacitors is if it is american made? I need in a library of film capacitors for a project in P-CAD 2006, but it has a .lib of Vishay with ceramic type only
              (Vishay vitramon ceramic dipped capacitor.lib)
                hi,
                I think this is of : NIC Components Corp.
                Type: Metallized Polyester Film Capacitor
                  thanks WM6. can anybody tell me what is right in American CAD standart/tradition a (re)number direction choice on a schematic Top to Botton or Left to Right? what will be more right, RefDes Auto Group Parts or Keep Parts Together?
                    Hi
                    Spice Support
                    ... and much more!
                    Can you see in Sprint Layout (39.9 Euros) a valid alternate to Dip Trace? I like it.
                      I use both and works excellent
                      Nelson
                        Nelson
                        For very beginner user you can see a Sprint Layout tutor at : http://electroni-city.com. It's not about you. You seemed to be very advanced in working with pbc software. I have something for you at the same address: how to make toner transfer using vinyl sticker and laser printer.
                        Have a nice day.
                          sharing torrent file. click on it, utorrent will start, or load the file in utorrent. enjoy.
                          this is FREE version
                          • at start of the soft take a data from Registration.txt
                          • version of the 1000 pins and 4 layers will be activated.
                          [Link to pirated software removed.]
                          Last edited by Qiaozhi; 12-04-2016, 07:33 PM. Reason: Geotech does not condone the distribution of pirated software.
