Very high resistence
  • Very high resistence
    Around 100 gigaohms!
    Are you making homemade ion chambers ?
    That hi-value-resistors... seems have few applications...
    btw, it works pretty good for that things...
    Kind regards,
    Max
      Are you making homemade ion chambers ?Max
      Exactly!
      Probably from the link i found some day, the problem is the gigantic value resistors.They are rare and expensive
      I don“t know if this transistor thing work, but it is interesting.
        Kind regards,
        Max
        Who knows... maybe is interesting. The most high value commercial resistor I can find here is 22 M. No, I'm not making homemade ion chambers!
          Just, only 22Mohm ???
          What place is that !?
          Seems impossible Esteban... do not find e.g. 39Mohm, or 68Mohm there ???
          Lets go back at the issue of large resistor...
          so, are you doing ULF receiver maybe ? Shumann resonance things ?
          Cause the list of applications for such hi-value-resistors is about short...
          Kind regards,
          Max
            Kind regards,
            Max
            Maybe is a curiosity the connection of the both transistor as very high value resistor. I post only for this. Do you think that only I think in such things for use in ion chambers or similar?
              Hmmm... I don't know... simply why the need of such hi-value-resistors if do not have an application for them !?
              Just another puzzle I think...
                As I see, you are a phanatic of puzzles...!!!
                  Yes, i do
                    HI
                    2x 50 G ohms =100 G ohms
                    olivier
                    http://fr.farnell.com/jsp/search/pro...sp?SKU=1174530
                      Originally posted by o.mag View Post
                      HI
                      olivier
                      yes, indeed...
                      but I think Esteban like make stuff with his own hands than sending money to Farnell or other gringos...
                      Kind regards,
                      Max
                        yes, indeed...
                        Kind regards,
                        Max
                        Possible(s) origin of word gringo.
                        http://ask.yahoo.com/20000821.html
                          always refers to gringos and gringolandia!
                          At the end... i'm sure Esteban will made his own hi-value resistors and saludos a todos los gringos!
                          Kind regards,
                          Max
                            yes, indeed...
                            Kind regards,
                            Max
                            I respect that.A ggod way to learn and stay independent
                            And he also post his finds for others to learn
                              Hi everybody,
                              I just wonder, is it possible adjust resistance of that transistor network?
                              Let say instead 100G just 1G.
                              Regards.
