testing tv remotes
  • testing tv remotes
    Can someone please tell me how to test a tv remote without any testing gear apart from a multimeter. I dont know if it is my tv or the remote that is faulty.The tv and remote are about 3 months old it suddenly stopped working,and while the tv works ok using the manual controls it will not work remotely. Have replaced batteries in remote and tried a universal remote as well.??
    Thanks in advance for any advice.
    regards minersright.
    If it's only 3 months old then it is most likely still under guarantee. The easiest way to isolate the problem (assuming you do not have access to a similar remote control for testing) is to take the remote back to the shop and test it on one of their TVs.
      Testing tv remotes
      Thanks for your reply qiaozhi but the problem is. yes the unit is still under warranty but i live so far away from where it was purchased that I would like to have some idea of the problem before I contact the dealer.
      regards minersright
        Better for all, if you have a mobile-phone or cd-camera. Look with your camera IR-LED your remote control.Push a button and you see bright in screen-camera.If you see bright, your remote control work right.
        Very easy method for check
          Testing tv remotes
          Thank you Andreas ,that test worked great. I used a known remote to see
          if it was going to work and it did work,I then tried the suspect remote and
          no result. A simple but affective test that I will remember for ever.
