Hi everyone!
First I want to know that generally how much power is required for an frequency domain EMI sensor's transmitter to produce enough eddy current in a soil having a resitivity of 30 Ohm/m, also.
Right now I customised a EMI receiver that consists of an sigma-delta ADC, a coil and a microcontroller, it could pick up signals in the background enviroment...
However, when I input the data into PC and use matlab to analyse it, I found some difficulties in extracting the InPhase and Quadrature components, because basically the data I obtained is coming from the superimposition of both primary field and secondary field... I need to find a way to removal this signal without doing something physically, since the core of coil is fixed and would be pretty hard to get a bucking coil inside... Is there a way that I could retrieve induced current solely generated by the secondary field in software (particularly, Matlab), would I/Q demodualtion be a good idea? and How should I do it?
Now its time to convert math to matlab code
