Hi everyone!
My coil has a resistance of 24 Ohm and a inductance of 13mH, and I'm using DAC8581 from Texas Instrument to drive the coil, the datasheet suggests:
The DAC8581 uses a high-performance, rail-to-rail output buffer capable of driving a 600-Ω, 200-pF load with fast 0.65-μs settling. The buffer has exceptional noise performance (20 nV/√Hz) and fast slew rate (35 V/μs). The small-signal settling time is under 300 ns, allowing update rates up to 3 MSPS. Loads of 50 Ω or 75 Ω could be driven as long as output
current does not exceed ±25 mA continuously. Long cables, up to 1 nF in capacitance, can be driven without the use of external buffers. To aid stability under large capacitive loads (>1 nF), a small series resistor can be used at the output.
Two things worries me at the moment:
1st, the DAC's outputting a 0-2.5V sine wave, when the voltage output of the DAC drops, the inductance of the coil will cause reverse current feed back into the output pin of the DAC, I'm worrying about it will damage the DAC component....
2nd, for a coil of 24 Ohm, how can I keep the current low while not keep most power on the coil instead of the resistor I put on....
