I made a weeklong project out of nothing because I'm cheap.
When I jog at night I like to carry a "light stick" which is powered by three button alkaline batteries. They are very nice trim designs, but the batteries do run down after a while. At local stores these batteries cost a lot and they don't last too long, so I thought I'd rig up some AAA batteries and strap them on to the light stick. Ok, bulky and clumsy, but like I said I'm cheap.
I bought some "Philmore" AAA battery holders at Fry's. Turns out these are very lousy quality because when you solder wires to the solder lugs, the mechanical connection to the interior battery contact (spring or rivet) heats up and for some reason becomes extremely high resistance -- open circuit.
You have to be careful soldering also because the lugs heat up and melt the plastic case and the contact can fall right out or misalign.
At least one battery holder didn't have a contact at one end. I spent an amazing amount of time messing with it. Conclusion - even easy projects aren't easy.
An interesting note -- the button alkaline batteries are 1.5 volt each, and three are used in the light stick. But when the light is on, the voltage drops to about 3 volts across all the batteries because of the current draw. So I found I had to use only 2 AAA batteries which had less internal resistance, or else the voltage was too much.
Of course I went mad trying to solder little connections here and there.
