DXF or PCBArtist files convert to Gerber
  • DXF or PCBArtist files convert to Gerber
    Hello has anybody a method to convert DXF Files to Gerber. I have open the SBG-Pi files with PCB Artist ,now i have a new Problem, i need Gerber for my PCB Maker.
    Can Anybody Help.I can send you the pcb. , the sch. , and the DXF File but i need Gerber.
    Many Thanks from the Harz Montains
    Send the files to my email, and I will convert the DXF to Gerber using EasyPC.
    I've just created an example DXF file for the top copper layer and re-imported it to create the Gerber file. No problems. You will most likely need to create a DXF file for each gerber layer that you require.
      thank you for your work for me i have send you the files include the originals greetings from the harz montains
        Have a look at your email.
        The tracking layers are missing from the DXF file.
          yes the main problem is that the original files are writen with pcb artist and from the original files i have make the dxf so ok i think i must rewrite the pcb with another program design spark or so by the way thank you for your work greetings from the harz montains
            Can PCB Artist not generate the missing tracking layers in the DXF file?
              I think no, pcb Artist is a limited Version from Advanced PCB (a PCB Maker).In the moment i try to rewriting the Schematic in designspark and design a PCB in design spark.
              I think the SBG PI is a "Beast" for Deep that is the ground for my work.I will build this Detector.
