Silverdog PIC meter problems-help?
  • Silverdog PIC meter problems-help?
    Bought a PIC cap., induct. meter kit from Silverdog.
    Cap. meter features works fine.
    Problem is Inductance meter feature will not work.
    I took this PCB apart twice, checked everything, even used new caps and resistors, wiring was checked over and over, I cannot find the problem.
    Inductance test with short stays at 0--AWAITING TIMING
    What do you think of this meter on ebay?
    http://www.ebay.com/itm/USA-LCR-RCL-...item5d32776c67
    Just a quick observation without knowing anything about this meter. Try using a larger inductance. Looks like you have just a jumper wire in the picture.
    Jerry
      Yep, your trying to test something out of the limits of the meter.
        But, per instructions for this meter:
        To test the LC oscillator, switch S2 to
        position 1 (inductance) and clip the probes
        to each other (as a short circuit). In this
        configuration inductor L1 completes the
        feedback circuit for IC3a, which oscillates
        accordingly.
        Adjust preset VR2 until the oscillation
        rate appears stable, as indicated by the frequency
        value shown on screen line 1. The
        setting will be obvious if an oscilloscope is
        used. If a scope is not available, try VR2 at
        various wiper settings and chose the best –
        it is not critical. In the prototype the author
        set the wiper for approximately three-quarters
        clockwise rotation (about 7k5).
        Again the frequency and calculated
        results are shown on the upper and lower
        lines of the screen. In the prototype typical
        un-nulled values are 468608Hz and
        11.492H. Pressing “null” switch S3 the
        inductance value should read 0·000uH
        Now clip an inductor of, say, 10H
        between the probes. A typical display
        might then be 342348Hz, 9·969uH. In this
        case showing that the external inductor is
        pretty close to its marked value.
        As with the capacitance mode, the pulse
        width assessment technique is used when
        the monitored frequency is below a certain
        value, 16384Hz for inductors. Again the
        frequency value is shown with three decimal
        places.
        On the normal frequency counting range,
        values less than 100H are displayed with
        a “uH” suffix, otherwise they are shown in
        millihenries (mH), i.e. 100.801H would
        be displayed as 0·100801mH.
        Values obtained using the pulse width
        technique are displayed in henries, with a
        suffix of “H”, for example 7.305H.
        Be patient when monitoring higher values
        of inductance, for the same reason as
        for larger values of capacitance
          I've not looked at the circuit.
          It stands to reason you have a open on the Osc?
          Corrupted Code on the PIC?
            hello sven
            i have that 4070L multimeter longer than 2 years
            works good
            but testing tips that are delivered with are crap
            so buy the meter and separate testing tips (maybe also a pair with croco clamps)
            and you have a good tool
              Thanks ordered one, 4070L multimeter.
                Hi SVEN1,enyou your new 4070L Chinese meter order,But please dont rely on its accuracy!
                I have several LC meter imports via China an Other,for homebuilds coils etc.
                If you do several or many home workshop checks for your coils.Please do a comparison check amongst your readings amongts meters.Errors are prevelant!
                .I have several Meter checks done.Via MIT. Certifiy for compliance and at Institute Cost$$ and most dont meet the Spec.? for LC.
                It concerns me often,hence the $$ compliance Test,compliance, and Accuracy tests from MIT.Australia.
                I do my LC checks via a suite of Meters.
                The best and with Mit. Testing at my cost $$ was the Silicon Chip Design Meter.
                from Altronics as Kit was K2533LC meter kit.
                A Short and Well built Bananna Plug/Aligator clip prob set was required for all! not just the supply test clips with any meter?
                Regards Rov.
                  Regards Rov.
                  Thanks,
                  I have a co-worker who has been an electronics tech and teacher for 30 years, I'll let him take the 4070 home and check it's accuracy with what he owns.
                    Check the inductor oscillator around IC3a, L1, VR2, C5a, C5b, C6a and C6b. With the probes shorted (and the switch at "inductance") it should be producing a signal at pin 11 of the IC. If it isn't you probably have a little solder short somewhere or a bad component.
