Level shifter
  • Level shifter
    Attached is a level shifter circuit. This works OK for a pulse width of 5us and more, but there is some propagation delay. The switching speed is also affected by the output voltage, in this case the battery charge level.
    Using HF transistors makes the switching faster for pulses of 1us.
    I am looking for a better solution, less propagation delay, better accuracy, faster switching.
    Any suggestions?
    Tinkerer
    Keep the PNP linear.
      Yes, a bit of emitter degeneration does the trick. Delays happen when transistor goes elsewhere from saturation. You may observe it as spikes in base current. Degeneration helps.
      I made some minor differences to your schematic, not to ruin your concept. Enjoy
        What about this one?
        (Who dares to optimize it further?)
        PS: The output doesn't need a mosfet driver! It has the driver built-in.
        Cheers
          I played a bit with ECL Schmitt trigger and it is now just some 20ns slower that yours, yet there are no nasty transients in transitions, and power consumption is just right
            Good one! I like it.
            Tinkerer should be happy now.
              Slight modification (other transistor) improves the level shifter + mosfet-driver + power consumption:
              Another proposal?
                Maşallah
                  Hey people, did anyone here actually included MOSFET gate as a load in these circuits?
                    Here is the complete TX schematic. I have not changed the level shifter yet, but will probably go with Davor's ELC, since I already have the mosfet driver. The mosfet driver needs about 6A peak current.
                    many thanks to Carl, Aziz and Davor for the great help. A genius is a genius. What is the plural of genius?
                    Tinkerer
                      This looks excellent, UC3710 is not mentioned, so i assumed circuit should drive FET directly. Never mind, i will add one more, completely unrelated post about ECL and it's speed, maybe interesting to someone.
                        See below.
                        No problem with the right complementary pair transistor stage (see below). Generally, a mosfet based mosfet-driver (complete IC) is more convenient of course (low power, low impedance, fast switching, high load drive capability).
                        So use the ECL driver above and feed it to the mosfet-driver IC. I personally like the ECL driver more than my proposal.
                        Cheers,
                        PS: The 2N2907 seems to be slower than the BC557-B.
                          More Drive Capability with BC368/BC369
                          Hi all,
                          if you need more drive capability, use the complementary transistor pair BC368/BC369. It delivers enough power for our purpose. Notice, I have a 20 nF load capacitance this time.
                          Cheers,
