Using "Bio-carbon" in ocean water.
  • Using "Bio-carbon" in ocean water.
    Here's an interesting bit of trivia I found in an
    old "Pyramid Industries" Catalogue.
    I don't know how accurate the information is!
    This is what they claim!........The following figures
    are based on PPM levels found in the 1989
    "Handbook of Chemistry and Physics"
    In many parts of the ocean, especially near fresh
    water outlets,gold has been found in much greater
    quantities. Gold in the ocean is no great secret.
    Every gallon of seawater contains .000011 PPM
    gold in a "Colloidal Dispersion" This is a large cluster
    of Gold or other ions that are smaller than 1000
    Angstroms in size. Once they are larger than this
    they will drop out of suspension.
    Approximately every 91,000,000,000 pounds of seawater contains 1 pound of Gold. Every cubic
    mile of seawater contains 9,188.096.200.000 pounds of water so there is 101 pounds of gold
    in every cubic mile of seawater,not to mention the
    other values. At almost $484,800.00 per cubic
    mile, it's worth exploring @ $400 per ounce.
    With these figures,we can estimate that every 120
    cubic yards of seawater has 1 cent of Gold.
    In order to earn $1 a day on 30 pounds of carbon
    [$3 per LB] approximately 220 gallons of seawater
    must pass through every minute. For profitability,the
    carbon would have to be in place for well over a
    year.
    Conclusion: $90 worth of carbon will yield $365.00
    worth of Gold in one year. Is this profitable?
    Just ask any stock broker if he can triple your money
    in one year.
    Re: Using "Bio-carbon" in ocean water.
    >year.
    >in one year.
    How about the cost of pumps,pipe,gas,site managemt to pump 230 gal per min. I do very well with my beach box. And it does seam to be true that i find more gold near fresh water. But i think it has more to do with abnomalites?(spell) I also do good next to a natural sea wall You can watch the tides and where the water slows
    down eddy,creek,big rocks,the black sand and gold will be in layers. Some times 4-5 layers deep 1/4 to 1/2 in thick. When you get it like that you can get a oz in 6--7 hrs
    Doug
      Hello Doug,
      Sounds like you're onto a pretty good thing to me!
      Imagine you being able to process ten,twenty or
      even a hundred times more sand than you do
      at the moment. Or perhaps it's only a narrow area
      that you are able to access. Have you ever used a
      "Goldspear" to locate the best Hotspots?
      I've got two of them. Bought one new and about
      twelve mths ago, I saw one for sale at "Mr Money"
      in Albany for $100. It even seems more sensitive
      than the one I bought new.
      Naturally it would'nt be feasible to pump water
      through "Bio-Carbon" as it would cost too much.
      At least it would for seawater. However they claim
      that many old flooded mines can yield as high as
      $2 of Gold per gallon but the average is .05 per
      gallon.
      The method used in seawater is the "Bio-carbon"
      is put in burlap sacks and hung from docks or Piers.
      In some cases it's preferable to weigh down the
      sacks and drop them to the ocean floor with a bouy
      marker for later pick up. They should be placed in
      an area with a good currant flow.The best gold in the ocean has been found at the 200 foot level
      and below.
      Here's a test that will show a piece of visable gold
      even if your water has only .05 PPM.[1/4 of part
      per million]
      1.Take five gallons of water from a suspected gold
      bearing water souce.Transport the water in used
      plastic milk jugs because the milk coating prevents
      gold from absorbing into the plastic as is the case with new plastic containers.
      2. Boil the five gallons down to 1/2 an ounce on a stove in a glass pan being careful never to let it
      burn dry. If the water totaly evaporates before step
      #3 the gold will become stuck to bottom of the pan.
      Note: If a white calcium residue is found forming on
      the sides of the glass container,add 1/4 teaspoon
      of Calgonite dish washing powder.
      3. Pour the remaining 1/2 oz. of water into a piece
      of 999999 fine lead foil that has been fashioned into
      a cup.
      4. Place the lead foil into an oven and evaporate
      untill dry. A film should now be visable on the bottom
      of the lead foil.
      5. Fold the lead foil into a ball and place into a cupel
      for 30 minutes @ 1800 degrees F.
      6. After cupeling,a very small bead may be present
      in the bottom.The bead may consist of gold,silver and other precious metals.
