Underwater video signal
  • Underwater video signal
    I just finish assembling my BW underwater video. I used for wiring 100 meters two conductors common wire, one of them is 12 V positive and other the back 1 MHz video signal. The ground
    (-12V)is made by the sea water using underwater stainless steel screw on the boat and outside the housing.
    I have degraded picture.
    Can I improve the picture quality using inside the housing a video amplifier or I must ajust the impedance/capacitance of the cable.
    Do you thing I can get good picture using normal wiring?
    Any help are welcome.
    Thanks.
    Francisco Xavier Sousa
    Re: Underwater video signal
    1MHz over 100m might require a better cable. Also, what is the supply voltage drop over 100m of seawater for your rig? You might have severely degraded the supply voltage to the camera.
      Thanks Carl for your advice.
      After spending hours around (until 6:30 Am Saturday) I could incrase the picture quality. The voltage (12 V) d'not decrase, the BW camera needs just few milamps supply. and the 100 m.wire just have 2 Homs. After changing a lot, I send by the cable the video signal and negative supply, the positive supply by the sea water. More I have to ajust the signal level just conecting a 10 KHoms potentiometer beteewn signal and negative (about 128 Homs) and the picture quality was great.
      I never expect to have this picture quality with 100 meters with a reel of common wire.
      So I think to use the same cable to work with magnetometer and after the vĂ­deo.
      Best regards Carl,
      Thanks,
