Detecting Caves and Voids
  • Alexismex
    Hello Forum ,
    To see very well the echo of the sound when you drop the weight i use
    - a sensor which is a used GEOPHONE
    http://psn.quake.net/geophone/index.html
    -a preamp with o without low fcy filter (i make with a 3 band filter)
    - a visual 100uamp meter or better for 25 Dlls !!!!this very good interface
    http://www.dataq.com/products/startkit/di194rs.htm
    with this you can see perfectly the echo produced in the display of your laptop......
    I will post a photo of my equipment
    THE SIMPLE FACT IT IS TO DROP A WEIGHT AND YOU SEE the echo IN THE MICRO OR DISPLA laptop LIKE IN MY EQUIPMENT YOU CAN HEAR THE SOUND also....
    To drop the weight at the same height i make a bloc of steel around of an axe because it is important to drop always the same height i will post also photo of this tool
    Geo it is not complicated to make i have tell the more important: geophone and logger...for the rest it is simple transistor fet amplifier and with a amp (741, tl071 etc...)
    another thing
    it is like a pulse detector
    you make the pulse (weight choc)
    1)and you measure the time after to have echo= this data is the DEPTH of the cave...(more time more depth)
    2) the more strong or amplitud of the echo = it is the size aprox of the cave....a big cave give a big echo
    it is "a priori " for cave to 5 meters ...to go more depht you must per-cut with more weight or with a hydraulic hammer like for archeologist surveys
  • Geo
    The same is happening with Gemini III. You calibrate it so to hear a small sound and when you are up from a cave or grave, the audio decreases the volume. But if up the cave or grave there is a fat ceramic plate, then the Gemini locates the plate, the stones etc....
  • Esteban
    Two box
    For example, the 08-MI 2 box by Mineoro (the old "direct conversion") with control of audio in transmitter can detect caves and holes. You need to put a small audio and see the microamp. When cave is detected (the depth deppend of the size of the cave) the audio decreased or vanishes and microamp work in opposite.
  • Esteban
    Deepers MD is manufacturer of cave detector. The problem is this: you need to carry a bag with 6-7 kg of sand. You drop it and listen...
    http://www.metaldetection.net/spanis...undSounder.htm
  • gwzd
    Sorry Geo,
    I wasn't paying attention, you are from Greece! No problems then, the FLB-390 is CE certified, compliant with the R&TTE directive 1999/5/EC and the EN 60950 CENELEC harmonized standard. So, no problems!
    RA
  • gwzd
    Hi qwzd.
    I have not experience on instruments for cave detecting.
    I want to find a simple detector for detect small caves or graves at small depth. GPR is not useful at my occasion because there are stones, small trees and also i want to take the results the same time (and always at night..... you understand ). From the other side the resitivity meters needs to put the metallic rods in the ground every 15...20 meters distance, a not practical work....
    So i look for something else....
    For a cave at 1 to 1.5 meters depth you need only 3 to 4.5 meters separation between the electrodes, or 9 to 12.5 meters in a four electrodes configuration. It might be still impractical for you.
    About the trees, well no geophysical instrument can go into those , to my knowledge anyway. The stones should not be a problem for GPR, there are "air launched" antennas specifically developed for such occasions, look here:
    http://www.geoscanners.com/antennas.htm
    Check the FLB-390 air launched antenna, specifically developed for that kind of surveys as cavities, voids, layers etc.
    Although, if you are in US you won't be able to use it, not yet anyway, it has to be certified with the FCC and we are still working on that, second quarter of 2010 if we are lucky.
    RA
  • Geo
    Originally posted by gwzd View Post
    Geo,
    That is exactly my point about calibration. For a gravimeter to detect such small voids at such shallow depths you'll need an instrument called "microgravimeter", the resolution being of the order of microgals. Relative measurements as you suggests, for units like those working very near the noise floor are unreliable, any noise can trigger a false alarm. The same concept used for other methods with much more stronger contrasts in the parameters they measure is not applicable to gravimeters. More on that, terrain topography and diurnal earth tides will complicate things further more. The point is that these equipment, even professional ones costing tens of thousands of dollars, is out of the reach of the average treasure hunter by the complexity and demand on training they present.
    That's why I was amused at the simplicity of the schematics presented and was a little bit sorry for Esteban being frustrated about the thing not working.
    Now, on the other hand, think about the resistivity even a small cave presents to an ER meter, nearly infinite! You won't miss that! Which is what I wanted to say, if you cannot use GPR for any given reason, then use ER methods. Nearly the same amount of work in the field as with gravimeters, but easier to put together, calibrate and test.
    RA
    Hi qwzd.
  • gwzd
    Hi.
    I believe that there is not need for accurate calibration. If you will pass up a known cave, you can calibrate it for audio output and nothing else....
    For me the question if, if it is so sensitive to "see" the gravity difference of a small cave or a grave at 1... 1.5m depth.
    Geo,
    RA
  • Geo
    I see only one little problem with this, how do you calibrate it? I find very difficult to find a reference for it. Of course, you could walk around with a very tall ladder, a well known weight and a chronometer, but that's just silly, isn't it? Another thing, how do you know your readings are not a result of vibrations?
    If I'd would do something that tedious, I'd go for a resitivity meter which is much more easier to construct, test, calibrate and operate than something that complex as a gravimeter.
    Hi.
  • gwzd
    You can measure by gravity. This demmand a sensor build by yourself. This is a sensor extremely sensitive to weight, exceptional, a small grain of metal deflects a microamp. strongly. This acts as an extremely sensitive variable resistor. This must not exposed to air, because the air produces strong variation. Also must be not exposed at vibrations. Now, you have my very useful copper plates-conductive rubber sensor.
  • gwzd
    Is There Anybody Out There?
    Pink Floyd
    http://en.wikipedia.org/wiki/Is_Ther...y_Out_There%3F
    Hi Esteban,
    You didn't get the subtle message, of course there is somebody out there, more interesting is the question whether or not is there anybody in there?!
    Other more mundane way to put it, knock, knock (the head), is anybody home? being outside or inside is always a relative question, and sometimes when Roger Waters has sung "is there anybody in there?" like in a concert in Stockholm, very few people have paid attention and notice the difference.
    But, very nice that you noticed!,
    Thanks,
    La idea no es saber si hay alguien fuera, sino si es que el/ella tienen algo en su cabeza :-), quizas son tontos! La solución de la pregunta a estar dentro o fuera es relativa y todo depende de el punto de vista que escojais. En ocasiones Roger Waters a cantado de otra forma pero muy pocas personas han notado la diferencia, como en un concierto reciente en Estocolmo. De todas maneras que bien que hayas prestando atención,
    Muchas gracias,
    RA
  • gwzd
    Originally posted by modaljar View Post
    I never have this complete valuable information in any forum.I saved it as a reference.
    I agree with every word you mentioned,and you answer every detail I wish to know .
    If I buy one, I will let you know.
    I wish you all the best.
    Mod Aljar
    Thanks, this is a good forum
  • Esteban
  • Esteban
    I can see now some members wasting time with useless posts.I wish if they can give some useful words here or there .
    I am sorry to see some members have hundreds of posts with no use.
    If you put much attention and understand some thinks and process, you can found useful info, deppend of you and your attitude.
  • modaljar
