Real time software for the Arc-Geo Loggers
  • Real time software for the Arc-Geo Loggers
    Real time software is here for the Arc-Geo logger and Pro models. You can see the grid as you walk it out. The Arc-Geo model uses the X, Y mode and the Pro model uses both the X, Y and GPS logging mode. Firmware upgrades are needed. Firmware updates are free under warranty but hardware upgrades are not, sorry. The pro will need a USB upgrade. You can see the X, Y mode video here. The Arc-Geo Mini is not supported at this time because of firmware.
    regards and good hunting.
    Tim
    Hello Tim,
    Good, very good in real time, hope you will make it also for the miniLogger and with the color version software.... it will be fantastic !!!!
    great time for you and thank you very much for your research
    Saludos
    alexis.
      Thanks Alexismex, I may look into working on the mini later next year. I will see.
      Tim
        The Arc-Geo Logger will be on the History Channel Jan 8th on the show DECODED. Check it out.
        Tim
          If you missed the show you can check my site for the you tube videos. YOu can see the short version here.
          Tim
