Had the ciccuit diagrams of the EPE unit (thanks satdaveuk) a few months ago having no experiance of digital systems i was very worried about any problems that may (would) arise. Decided to make a simplified unit on vero board first. Built a square wave osc 137Hz using a 555, removed the neg supply gen and voltage regulaters just have 2 x 9V batts, using a multimeter to measure output V which changes a I move across my small lawn.
Now have to take it out and field test it which i hope to do over next week, only a small 20 x 50 meters area note down readings and then manually input results into Snuffler.
Have then to build or buy a data loger hope to use one of the ardueno or similar systems, regulate the supplies etc.
Any ideas circuits or program sources,
