Hi!
I'm putting MY sensors SMD. I avoid each metal around the sensor. On our forum shows the sensor mount bracket rail alu; I never suggested the tube!
The coil inside the tube (Al or Cu) always gives problems with eddy currents and reduces its inductance. Application of the metal support bracket causing asymmetry.
I use the tube 50 mm PVC to the central vacuum cleaner is the most rigid of the available on the market Formerly I tried spinning tube 22 mm.
Best regards. Chris.
