Search for infos - Gps data logger and Software
  • Search for infos - Gps data logger and Software
    Following problem,
    i have a analog magnetometer which produce a signal to drive two antiparallel led as signal meter.
    An aditional board can be used to generate a tone according to the voltage input
    so enough points to collect some datas.
    First problem
    How can i log the datas? - voltage and gps point with a adjustable frequency maybe 10Hz-0,5Hz
    second
    what software can i use to genarate a graphic or ar measuring map (google map track+log datas)
    something similar like the map in this link
    A blog that covers issues in archaeology, historical science, evolution, remote sensing, and the philosophy of science. And surfing.
    or somethink like the geo surfer software with real map combined.
    I'm using the Surfer is extra.
    I did a variety of options.
    Most GPS at the start and end of each track.
    Now I find that you only need to start the first path.
    Use Google Maps for each measurement gave the result as alkochol.
    Always add measurements: start and stop each track to the results!
    Best regards Chris.
