There is a PI design on the market now - The VibraProbe. The selling points for it are:
- It vibrates when near metal, which makes it good for use with headphones (for the main detector), or near surf - so that you need not strain to hear a beep.
- It's waterproof - so again, it's good near the water.
However, the detection range is less than 1 inch.
I think if low cost / simplicity are needed, PI seems like overkill. A design factor I failed to mention the first time around is the need for a small coil. I picture the whole 'coil' fitting into a 1" (or so) diameter PVC pipe, with the coil at one end and the circuitry at the other end (maybe inside the pipe, maybe in a box)...
Carl - You mentioned a VCO design - is there a reference to this type you could point me towards (no pun intended!)?
thanks - Mark
thanks - Mark
