Aren't you all yearning for a medium-range-detector which is lightweight and easy to handle?
Hahaha - I had a great idea - here's the deal - even for free:
We all know the compass-needle-effect - not only if a magnet comes close to the needle it moves
but also with other "magnetical" metal - check wikipedia for the different types of magnetism.
With enough sensitivity the treasure-hunter can find anything what disturbs the usual earth-magnetism
by holding some device which shows on screen the exact values of front, back, left, right, up and down.
So at least 6 high sensitive gradiometer-circuits in combination with an LED-screen are needed. *
The more sensitive the smaller will be the detector or the more narrow the place of the sensors.
* better 7, one additional in the center
The tests are pretty simple - first the device will recognizes any 5 meter distant cars and
after fine-tuning it will be able to detect at least an object the size of a horseshoe or smaller.
It also reacts on ore-veins etc. but the point is that its handheld and very lightweight.
And it does not work like those usual "imaging"-magnetometers with their pretty colors Hahaha
but it measures all the directions and calculates the differences and perhaps even the distance!
