Re: Virus alert
  • Re: Virus alert
    Thanks, I would appreciate a chance to see the article. I have a ML Dalton
    two fish boat towed mag but am always interested in new tools.Have just had
    the opportunity to try out my Dan's side scan sonar and was rather pleased
    with the results. Hope to have my tow tec boat towed metal detector finished
    by the weekend so I can try it out.
    thanks again,
    Charles
    ----- Original Message -----
    To: The Proton Mag Forum
    Sent: Wednesday, September 27, 2000 9:15 PM
    Subject: Re: Virus alert
    > --My mag. is to be used on land.
    > If it is of any interest, I have a copy of the plans for a differential
    magnetometer from a 1960 vintage "Skin Diver" magazine. AS the saying goes
    'been there and did that -until I was washed into a barnicle covered rock
    off Plaos Verdes, Calif.A quick way to loose weight!
    > It is a kinda sorta modernized version of the original English
    project.It was ment for above salt water use and has a couple hints on how
    to keep the thing running once it has been dampend with salt water ( Lots of
    WD-40!). It was copy righted, I guess it would be OK to scan it if you are
    interested.
    > I built the stand-alone mag. to get an idea of what it will take to
    successfuly get the gradiometer going.
    > GwBower
    > >George, will your mag be for land or water use ? Thanks for the virus
    > >warning.
    > >Charles, Oak Island, NC
    > >From: george bower
    > >Sent: Tuesday, September 26, 2000 10:24 AM
    > >> this virus has been spreading through my companies E-mail system for
    the
    > >last month inspite of a intensive camplain to stop it. The latest McAfee
    > >update will catch and remove it.
    > >> For what it's worth, I have built the "stand alone magnetometer" as
    > >designed by J Koehler and am working on a much simplifed toroid winder
    > >"inspired" by my companies winder.If I can get it to work,I'll put it on
    the
    > >forum.
    > >> GwBower
    > >> >I have today received an e-mail virus with the subject " Fw: Life
    stages
    > >text", and an attachment Life stages.txt.shs. I am warning you as you
    are
    > >in my address book, and although I have completely destroyed the
    offending
    > >e-mail and there should be no risk to you, it is as well to be warned. If
    > >you receive this mail, delete it and remove it from your "deleted items"
    > >folder. If you don't use MS Outlook or Outlook Express you should not be
    > >affected.
    > >> >Cris.
    > >> >_________________________________________________ _____________________
