Proton Magnetometer
  • Proton Magnetometer
    Hi Subscribers.
    From long I was reading everything about magnetometers and decided for the
    fluxgate FGM3h frequency output.
    I assembled a diferential using two of this sensors. I designed pc board in
    order to sharpen sensors output reading the diference of both frequencies.
    In order of the very high orientation sensivity I had to fix it in hard and
    heavy PVC tube. It have good sensivity, about, 0.3 gamma and work very well
    when quiet, but was impossible to allign the sensors in order to have the
    same readings when moving or spinning the gardiometer. With the normal
    rooling under water I found random variations of 70 gammas.
    Defenitively I will go forward to Proton Mag once it is quite insensitive to
    direction. Do you can help me on schematics?
    Any help will be apreciated.
    Thanks on advance
    [email protected]
