Re: Transistors used in Huggard Proton Magnetometer??
  • Re: Transistors used in Huggard Proton Magnetometer??
    Hello Henrik,
    I found following Info in my Library about the Transistors:
    2N5088, NPN-Silicon, VCEOm: 30Vdc, Icm: 50mA, Pd: 625mW, fT: 50MHz,
    hfe: 350~1400 -> Motorola Type (pdf-avail.)
    For these ones I got only short Descriptions
    [Material,Type/App,(VCEm,Icm,Pdm),equivalents):
    2N2712, NPN-Silicon, B>75 equiv: 2N2711,BC168,BC183,BC238,BC548...
    2N2613, PNP-Germanium, LF-Type, 30V, 0,05A, 0,12W equiv:
    AC125..126,AC151,2SB54,2SB56
    2N2643, NPN-Silicon, Dual-Type ! ,45V,0,03A,0,5W, ft>40MHz equiv:
    BFY81,2N2913..20
    2N404, sorry no Info available (perhaps obsolete)
    Greetings
    Oliver - Germany
    Valentin Mortensen wrote:
    > The Proton Mag ForumAfter looking at several different suggestions how
    > to build a differential proton mag. it looks to me that the simple way
    > is the "Huggard" way (the articel from 1970). But since I am not a
    > electronical expert, I have some problems to get the transistors.
    > Anyone have an idee how to the
    > transistors?2N50882N27122N26132N26432N404or transistors that
    > correspond to the one used in the construction.Henrik - Denmark
