Treasure finally found with mag !
  • Treasure finally found with mag !
    >hi guys--
    >curious---
    >about 35 years ago--made that which was called,in
    >the day,an electroscope----you know the foil
    >leaves attraction/repulsion stuff---electrostatic
    >electrophorus etc...
    >the only real world practical use of such (recentish)
    >was/is in my later years of life learned---is that
    >called a dosameter---you charge the thing--measure
    >angle of deflection--drop in a radioactive suspected
    >substance---then time/loss of charge (think it had
    >to be positively charged) gave a semi-qualitive
    >quantitive indication of activity...
    >my question is--how is the electroscope of then
    >related to the electroscope of today (so-called)..
    REPLY by DELL:
    No Relationship whatsoever!
    Re: electroscope
    oh-so its just that someone decided to call it the same name---why did they (whoever)not coin another
    word to call it so as to minimize any......
    >>hi guys--
    >>curious---
    >REPLY by DELL:
      Re: electroscope
      >>hi guys--
      >>curious---
      >REPLY by DELL:
        Re: electroscope
        so then someone decided to call it by the same
        name---why did they (whoever) not coin another
        word to call it so as to prevent.....
        >>hi guys--
        >>curious---
        >REPLY by DELL:
          Re: electroscope
          As Dell said, there are no similarities.
          The Electroscope (by Thomas) of today is a voltage enhanced dowsing rod. When everything is connected up correctly, there is supposed to be an adjustable open-circuit voltage applied between two of the three antennas, and the third antenna.
          I'll refrain from further comment, as it has been discussed on the LRL forum adnauseam.
            Re: electroscope
            adnauseam.
            thanks you to add to my vocab. a new word---had to look that one up....made me laugh---that is the
            definitions' "wordage"...
              Hi Guys
              When I arrived 2 years ago at the Southernmost tip of Africa, a
              local guy told me he had located the wreck of a Portugese sailing
              ship ( which we call the "Nostra" ) under several meters of sand at
              low water mark, by towing a mag in a rubber tyre along the sand at
              spring low water.
              Last week I got a call to fix an underwater camera/floodlight that
              they are using on a blower to expose the wreck, and it looks like
              they have found it !
              It gives me hope to finish my PPM, there are loads of wrecks along
              the coast !
              Good luck all
              John Smith
              L'Agulhas
              South Africa
                RE: Treasure finally found with mag !
                Well done to you all.
                Keep up the good work. Don't give up on your PPMag!
                Carroll O'Donoghue
                Ireland
                -----Original Message-----
                Sent: Tuesday, July 31, 2001 8:05 PM
                To: The Proton Mag Forum
                Subject: Treasure finally found with mag !
                Hi Guys
                When I arrived 2 years ago at the Southernmost tip of Africa, a local guy
                told me he had located the wreck of a Portugese sailing ship ( which we
                call the "Nostra" ) under several meters of sand at low water mark, by
                towing a mag in a rubber tyre along the sand at spring low water.
                Last week I got a call to fix an underwater camera/floodlight that they are
                using on a blower to expose the wreck, and it looks like they have found it
                It gives me hope to finish my PPM, there are loads of wrecks along the
                coast !
                Good luck all
                John Smith
                L'Agulhas
                South Africa
                __________________________________________________ ____________________
                  Re: Treasure finally found with mag !
                  What plans did you use for yor mag? I have been trying to find out
                  who put a set of plans on the AOL hometown without success. At the
                  bottom of the first page it says under construction. I don't know if
                  these plans are complete or not.
                  Rick Angove
                  ----- Original Message -----
                  Sent: Tuesday, July 31, 2001 3:05 PM
                  Hi Guys
                  at low water mark, by towing a mag in a rubber tyre along the sand
                  the coast !
                  Good luck all
                  John Smith
                  L'Agulhas
                  South Africa
                    Hi Rick
                    It wasnt my mag they used, mine is still a very experimental thing
                    that has sat on the shelf for 20 months, waiting for me to get some
                    time to finish it :-)
                    I am sure there are people in the group that can help you with plans
                    Cheers
                    John
                    Sent: Monday, July 31, 2000 11:18 PM
                    Subject: Re: Treasure finally found with mag !
                    if these plans are complete or not.
                    Rick Angove
                    Hi Guys
                    sailing ship ( which we call the "Nostra" ) under several meters
                    of sand at low water mark, by towing a mag in a rubber tyre
                    that they are using on a blower to expose the wreck, and it
                    looks like they have found it !
                    along the coast !
                    Good luck all
                    John Smith
                    L'Agulhas
                    South Africa
