Hi all,
I have a proton mag and did my first survey this past weekend. I have generated a contour map which shows a hi (red) area and to the northwest is a low (blue) area. I surveyed this 20ftX20ft area because I am hoping there is a box buried there. I am having some confusion as to where the object would be located. Is it in the center or transition between the 2 areas? or more toward the red, hi area? Also not quite sure the low area is to the NW rather than to the north of the high.
I'm hoping someone here has some experience interpreting these maps and can shed some light on where the iron object causing the magnetic dipole to be.
Thanks a lot
Thanks a lot
