Fluxgate magnometer
  • Fluxgate magnometer
    Hi Carl
    in projects page I saw your new mag.
    how does it work .did you like it.
    Did you have field test.
    can it locate your hidden materials.
    can it find precious metals (gold,silver) .and what about the sound.does it differ for different metals .are sounds for gold and cavity same or different.
    and is it posible to connect it to pc.
    accurate locators have geosurveyor program that you could download free.
    thanks
    okantex
    and
    what is the max dept for ferrous .non-ferrous and cavities that you could detect.can you give sizes and depts and type of materials
    thanks
      Hi
        Fluxgate Magnetometer
        and
        thanks
        Attn : Sales Manager Export
        We are a trading company, we are involved in import and sales in pakistan
        One of our customer requires,
        ITEM NAME SPECIFICATION
        D/I Fluxgate 1. Display: 3.5 digit LCD display with backlight.
        Magnetometer with 2. Measuring range: +/- 200nT
        Steel free theodolite 3. Angular Resolution: 1”
        & steel free wooden 4. Temp Coeff: <10ppm/degree centigrade
        tripod. 5. Operating Temp: 0 degree centigrade to +60 degree
        6. Resolution: 0.1Nt
        7. Connecting Cable: 5 meter
        8. Power: Battery operated 11-15V DC or AC
        9. Theodolite: 101A/010B,steel free Zeiss based theodolite
        10. Protective carrying case
        11. Face left/face right error<5”
        12. Steel free wooden tripod
        13. Sensor
        FLUXGATE 1. Microprocessr controlled data acquisition system (P-IV,
        Magnetometer. 19’ LCD flat screen, keyboard, mouse etc. )
        2. Related software
        3. GPS receiver with time correction
        4. Analog output: +/-10V
        5. Digital output: 8 Ch/16 bit ADAM AD-cnverter
        7.Compensation: Field Range +/-64000Nt
        8. Compensation Field steps: 150Nt
        9. Sensor axis: <2 mrad
        10. Long time drift: <3 Nt/YEAR
        11. Temp. Coeff of sensor: <0.3T/degree centigrade
        12. Temp.Coeff of electronics: <0.1T/degree centigrade
        13. Resolution of temp:0.1 degree centigrade
        14. Band pass: DC to 1 Hz
        15. Range of compensation: +/-0.5 degree centigrade
        16. Factor of compensation: >200
        17. Power requirement: 220-230 VAC,3W
        18. Operating Temp: 0 to 60 degree centigrade
        19. Optional power supply: 10-18 VCD,3W
        20. Sensor
        kindly send quotation as as possible.
        Best regards,
        M M DURRANI
        Business Development Executive
        PCM Hitech Systems
        B-174, BLOCK-10
        GULSHAN-E-IQBAL
        KARACHI - 75300
        PAKISTAN
        Tel. : +92 21 4971419, 4971247
        Fax : +92 21 4979866
        e-mail : [email protected]
        web site : www.pcmhitech.com
