it is important to clarify two distinct concepts resolution and sensitivity. These two parameters are often confused. For fluxgate sensors, the core parameter is resolution, and sensitivity can be improved through operational amplifiers or other means.
Feedback types can be divided into two categories: open-loop and closed-loop. Open-loop fluxgate sensors have the advantage of high resolution but suffer from low linearity consistency. Closed-loop fluxgate sensors, on the other hand, offer precision but have slightly lower resolution.
Among common low-cost fluxgate sensors, theGM-3 is an open-loop type with high sensitivity but slightly worse linearity. This nonlinearity is caused by the nonlinear magnetic permeability of the material under different magnetic field strengths different frequency hysteresis losses. The FLC100 is a closed-loop fluxgate sensor with perfect linearity. The key factor limiting the performance improvement ofgate sensors is Barkhausen noise, which is determined by the magnetic core material. The resolution of the FLC100 fluxgate sensor is 3nT, which is the limit of the performance of a single bar-shaped fluxgate sensor. Some people attempt to improve sensitivity by replacing the magnetic core of the FLC100, which is joke and a clear confusion between sensitivity and resolution. Under certain specific conditions, sensitivity may indeed improve, but that is an incorrect state. Isn't it simpler to add an amplifier use a 16-bit ADC? Another joke is to say what the inductance of the FLC100 magnetic core is. The inductance of this structure significantly under different magnetic field strengths, and different measuring methods and instruments will also put the magnetic core in different states. Therefore, comparing inductance is a meaningless thing.
How we take advantage of each other's strengths and minimize the impact of weaknesses in use? For example, pairing with FGM-3 is a very difficult task that requires a lot sensors to be selected from. This is even more labor-intensive than manufacturing sensors. The paired sensors are expensive and far exceed their value. The simplest method is to ensure the direction of the sensor during use, and it is very effective to use a 16-bit ADC with the FLC100 sensor and add filtering algorithms.
of the things that are most easily overlooked when using fluxgate sensors are power supply and the stability and coaxiality of the mechanical structure. Mechanical vibration is also a major source noise. Regarding the distance between the two sensors in the gradiometer, theoretically speaking, the farther the distance, the higher the resolution. However, the farther the, the more difficult it is to ensure mechanical strength. This requires a balance. Professional gradiometers typically have a distance between the two sensors of 70cm or 10cm.
Regarding 3D software, the communication of Euromag 3D is encrypted, while others are generally plaintext communication. It is easy find the communication format and baud rate. As long as the Bluetooth is set correctly on the MCU side and the data format sent is correct, these 3D software can used. Due to busy work, I rarely visit the forum. If you are interested in in-depth discussion, you can communicate with me through the following methods
Whatsapp:+852 62327564
email:[email protected]
Aliexpress:www.aliexpress.com/store/1104214418
