The magnetometer project section has links to dated designs referencing the FGM-3 sensor, which is no longer available [Admin note: FGM sensors are still available through Speake, see post below]. However, a new sensor technology has appeared which surpasses the performance of the FGM-3 sensors. Honeywell has released the HMC series of magnetic sensors which use miniature on-chip magnetic film sensors with the same resolution as the FGM-3 sensor, but use only 6 ma for 2.7nT resolution, without the bulk or long cycling times needed by other types of sensors. These new sensors can be used in the same basic designs as the current projects, but with simpler circuitry and fewer components. The HMC1001 and HMC1002 seem to have the best resolution in the group, and cost less than $25.
Here is an overview of magnetic sensor products from Honeywell:
Here are some honeywell schematics for a simple gradiometer circuit:
Application notes, tech article and software downloads for these products here:
You can buy a 1-axis, 2-axis or 3-axis sensor ICs starting at about $15 here:
PNI also sells small boards with magnetic sensors with a resolution of 15nT for about $45.
These PNI sensors use a different technology with inductors that sense the field.
