I got it all together, flipped the power switch to ON and, it works, YEA...
It came right up just like the instructions said. I messed with the tuning and it seems to work pretty well also. I used the mounting system from the plans that came with it and all went well. If your thinking of building it, it can be done. This is not a first time project and some pretty good soldering skills will help as the board from Fat quarters has some pretty close pads on it. Take your time and build each piece with care. If you botch up a part just rebuild it, don't try to make it fit...
I will be field testing it and I will let you know how it goes.
Fitz.
Fitz.
