magnetometer
  • magnetometer
    Hi
    i found this pdf Chanceful and it seem to be easy project, and i want to know any of you built this magnetometer or not? if yes , what is the performance?
    all the best
    mehdi
    and this magnetometer:
      not any reply?!!!!!!!!!!!
        I don't know much about what you are going to use it for, but I would add some kind of gain control. I'm new to the subject so I hope I didn't insult. Typed to soon, the PDF one has it. I also noticed that the OP amp iin the picture should be flipped, so that the + input is on the bottom then ground it and the leg of the coil on the side with out the resister. just realized, you will need to invert the output from the first OP amp so that the 3914 will read correctly
          On the PDF I don't understand why use a audio chip amp ahead of a 4069 then amp the signal, then a OP amp as a buffer. I would amp the signal from the transformer with an OP amp then filter, then to the 3914. I hope someone knows more about this then me.
            Hi Tomas and thanks for reply
            i want to find archaeology place underground and iron sword with it!! can it find those?
            do you built this magnetometer?
              No, I have not built one, but the PDF one looks interesting. I will try that one to see what happens.
                ok, please let me know if it work good ofter build.
                i am building the pdf one too but i cant find LM380 and LM3014 yet but i ordered and those will arive me ofter about one week.
                best regards
                mehdi
                  Gotta keep a eye on this one. I have most the parts.
                  I too think a second gain section with a control sections would be cool.
                    Originally posted by mehdi View Post
                    Hi
                    all the best
                    mehdi
                    I just built this magnetometer. It is probably strictly spoken a toy, rather than a piece of scientific equipment. On the other hand, me being a novice, I think it is awfully sensitive.
                    I already bought the PCB a while ago, and that means you need the LM380 with 8 pins, while most people have the 16 pins version in stock. However, availibility of the PCB makes this a nice project for anyone with basic soldering skills.
                    I will use it in an eartquake simulator demonstration for children at the geomuseum in Norway where I am employed.
                    My next magnetometer will be one with LCD display, datalogger and professional sensors.
                      Hi ronwer224
                      thanks for reply.
                      all the best
                      mehdi
