Re: My opinion of the Dalton unit.
  • Re: My opinion of the Dalton unit.
    Carl,
    Since this is your house I'll let you have the last word. Have a nice day. Jungle Jim
    Re: LRL Statement
    Carl,
      That is what I meant to say.
      The sensor on the Geometrics I have is a 3-axis sensor. Kind of
      like 3 sensors at different angles. If anyone wants me to send a
      small photo of the sensor to the list, let me know. I would assume
      that some of you have never even seen what one looks like.
      Thanks Jim!
      Patrick
      Jim Koehler wrote:
      The Proton Mag ForumHi guys,
      The Dalton mag is a gradiometer - that is, it is sensitive to the
      difference between the two sensors.The Geometrics unit Patrick is
      referring to is, I believe, a single magnetometer only. The big
      advantage of a gradiometer is that it is not affected by general
      changes in the earth's magnetic field due to ionospheric currents.
      At low magnetic latitudes, the local magnetic field varies fairly
      slowly and not very much. At high magnetic latitudes, you can get
      very rapid and very large changes in the magnetic field on the
      ground. Up at Churchill, Manitoba, at the rocket range, I have
      seen changes in the magnetic field (on the ground) of more than
      1000 nT over a time period of about 5 minutes. Using a single head
      mag. like the Geometrics (or any other single sensor mag.), you
      can't tell if the change you are seeing is caused by something
      you're going past or by the ionospheric currents overhead.
      I have seen a Dalton mag. owned by one of my neighbours down here
      in Arizona and, in my opinion, it is not worth the money. It is
      essentially identical to the gradiometer that Phil Barnes
      describes with one small difference. Dalton passes a small DC
      current through one of his sensors during the 'readout' phase so
      that you get a slow beat even if there is no magnetic material in
      the vicinity. Changes in the local magnetic gradient due to nearby
      magnetic materials then cause a change in the period of the beat.
      He calls this method the "delta-squared' method because he
      observes this 'change in the difference' - the difference being
      due to this small DC current. This helps but, in my opinion, only
      slightly. Unless you are going to invest in a portable chart
      recorder, it is very difficult to hear, through earphones, any
      meaningful change due to small gradients in the field. I must add
      the caveat that I've never taken the Dalton unit apart or looked
      at the insides. I've just seen the unit, seen it operating and
      read the literature he provides. The unit I saw was built more
      than three years ago and I have no idea how much, if any, he has
      improved it since then.
      All things considered, I'd just buy Phil Barnes excellent
      construction CD (http://members.aol.com/phil770/index.htm)and
      build the Phil Barnes unit. It works, has readily available
      components (most of these can be bought at a local Radio Shack
      outlet), is simple and inexpensive, and is essentially the same
      thing as the Dalton unit. The sensitivity is, as I've described in
      my overall document, about 25 nT, give or take. For a gradiometer
      of this type where you are listening to the beat, you want the
      signal to decay very slowly and hence probably want to use
      distilled water as the liquid since it has a decay time constant
      of ~3 seconds. Kerosene has a decay time of ~0.5 seconds so
      wouldn't be usable in this type of mag. - the signal just fades
      out too rapidly - you need to measure the frequency electronically
      over this short a period.
      The 'stand-alone' unit I've described in my most recent addition
      to my Web pages can use any liquid and gives a digital readout and
      has a resolution of about 0.1 nT. However, it is a single sensor
      unit, like the Geometrics, and has the failings of a single sensor
      unit. For prospecting on the ground, you probably will want a
      gradiometer and that requires two single magnetometer units. I've
      finished my gradiometer but am making minor changes in it and am
      not ready to release the plans till I'm sure all the i's have been
      dotted and the t's crossed.
      My 'stand-alone' mag. can probably be built for approx. $100 -
      that's the cost of the parts and assuming that the labour,
      provided by the builder, is free. The gradiometer requires two of
      these units plus an additional few parts. I'd estimate a total
      cost of about $300.
      JimJ.A. Koehler
      3290 N. Koehler Rd.
      Florence, AZ, 85232
      Ph: (520) 868-1156
