BLISSTOOL LTC64X id tono
  • BLISSTOOL LTC64X id tono
    como idx pro
    3 channel with double tone id is better variant..
      someone could put schemes to build 2 tone in blisstool
        Originally posted by scs View Post
        www.youtube.com/watch?v=PUp-BakXB3k
        Hi scs, can you put a schematic of yout 3 channel detector here?
          Scheme can make up alone .Two channel ground.First channel make signal down and second channel make signal up.Very close ground phase signals . Discriminator-third channel.
            Thanks. Why you need two channel ground cancelling + one channel discr. method if you can do the same simple by using antiphase RX coil?
              Man can swim, but uses a boat ...
