I am trying to mod my newer Tiger Shark into and interchangable coil type. Is there an IP68 panel 4 pin connector that would work to replace hardwire connector ? I also can install a bulgin 400 connector inline past the hardwire connector. My tiger is 12.5 kHz. Is it possible to use the Tesoro HOT style 4 wire coil which is for 14 kHz units ? I know the 10 kHz Umax style coil will work but don't know if the Tesoro HOT style will.
Any info from any of the pros on this forum will be greatly appreciated. I have the experience in the wiring portion, I just don't have the knowledge of kHz to know. If I try to do this as an experiment...will I hurt the machine by trying the HOT coil ?
Thanks in advance. LH
