simple IB geb CH sampling can only average out a single phase. As soil has a range of phases, So the background can only be reduced by a large percentage, but there is always some there. So user cant drop the sens level Really low - otherwise it would beep at ground.
With dsp techniques it should be possible to look at the range of gnd signal phases and to average them all down. Real target threshold could then be correspondingly lowered.
Or another approach may be to allow the GND signal to come thru on 2 channels - and fed into a diff amp. So the gnd signal ( with a range of phases ) would dissappear.
To get a real amplitude delta the Rx CH's could be on different frequencies, then almost all targets would give a different amplitude resonse and the diff amp would catch it and beep.
