Can the SAT speed on the Tesoro Eldorado (uMax type) be adjusted or changed? I would like to increase the speed.
Tesoro Eldorado SAT
The Tesoro Eldorado (uMax) SAT is always on in All Metal mode. All Metal is a threshold based, motion mode. SAT does not have any external switches or pots, preset at factory. I wanted to speed up the SAT with an internal adjustment or component swap.
Replacing a component on an analog pcb isn't rocket science, I thought someone that has done it could point out the correct internal pot to adjust or controlling component to change out, along with a little diy advise. I have done many internal mods on other Tesoro Factory built units, it's not difficult, if someone shows you what to do.
