Modifications to Whites Surfmaster II
  • Modifications to Whites Surfmaster II
    Do any one have the Modifications circuit to Whites Surfmaster II
    sound like to Do any one have the Modifications circuit to Whites Surfmaster II offered by Mr. Bill
    http://www.surfscanner.com/Surfscan3/Surfmaster_II.html
    https://www.geotech1.com/thuntings/s...ght=Surfmaster
    is $85 a charge for anybody?
      Surfmaster II Mods
      Here’s what you do to increase the sensitivity of the Surfmaster II VLF unit.
      Replace resistor #R7, that most likely is 100 ohms with one that is 51 ohms. This will drive the coil a tad bit stronger. This is off of the MPS3638A #Q1 transistor.
      Go find resistor #R24, that’s connected right off the sensitivity control at the board. That resistor will most likely be 470k ohms. We want to change this to a higher value. I usually use a 2.2m ohm here, but in some cases it’s a bit on the strong side. Perhaps a little trial and error may be in order ??
      This should improve your unit noticeably. Have fun.
      Mr. Bill
      Surfscanner Detectors
        dO YOU STILL DO MODS ON THIS DETECTOR OR DO I NEED TO GET NEWER UNIT.
          Yes I still do work on them.
          There are no newer models. Whites stop manufacturing them.
          Mr. Bill
